Self Osc in output on 41-296
Thanks guys. Good thoughts, and I do suspect a lot of this wierd stuff is not having the loop hooked up. I plan to take it down to my friends place later this week and re-install it in the cabinet. We will see what happens then. Other than that little oddity, it is working great. I was very surprised how well the audio sounds with the 12" speaker just sitting on the floor. Can't wait to hear it in the cabinet. This was my first Philco to work on, and have learned some and really enjoyed it.
Here is gallery of some of the vintage ham rigs and one "farm radio" I've done over the last few years:
http://w5ami.net/cpg1419/index.php?cat=5
Thanks so much for all the help!
Brian / w5ami
Self Osc in output on 41-296 - by w5ami - 04-17-2013, 04:06 PM
RE: Self Osc in output on 41-296 - by morzh - 04-17-2013, 06:19 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-17-2013, 08:14 PM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-17-2013, 08:21 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-17-2013, 09:21 PM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-17-2013, 10:03 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-18-2013, 06:38 AM
RE: Self Osc in output on 41-296 - by w5ami - 04-18-2013, 06:55 AM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-18-2013, 09:39 AM
RE: Self Osc in output on 41-296 - by w5ami - 04-18-2013, 09:47 AM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-18-2013, 04:20 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-21-2013, 03:08 PM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-21-2013, 03:26 PM
RE: Self Osc in output on 41-296 - by Raleigh - 04-22-2013, 04:28 PM
RE: Self Osc in output on 41-296 - by 7estatdef - 04-22-2013, 05:06 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-22-2013, 05:35 PM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-22-2013, 07:47 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-22-2013, 07:57 PM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-22-2013, 08:36 PM
RE: Self Osc in output on 41-296 - by Mondial - 04-22-2013, 08:50 PM
RE: Self Osc in output on 41-296 - by 7estatdef - 04-22-2013, 09:19 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-22-2013, 10:21 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-23-2013, 01:42 AM
RE: Self Osc in output on 41-296 - by Raleigh - 04-23-2013, 02:57 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-23-2013, 03:05 PM
RE: Self Osc in output on 41-296 - by Raleigh - 04-23-2013, 04:35 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
