Odd Heater String 116X
No, have not been on the air lately either. My 80M dipole came down a while back and haven't had a chance to put it back up.
The 6A5G is a really interesting tube and was the ultimate audio power triode design. Hi Fi amps were still being made with it into the 1950's. Here is a link to the data sheet:
http://www.bunkerofdoom.com/tubes/syl43/...43/p71.gif
Odd Heater String 116X - by 7estatdef - 04-19-2013, 09:22 PM
RE: Odd Heater String 116X - by codefox1 - 04-20-2013, 03:54 AM
RE: Odd Heater String 116X - by Mondial - 04-20-2013, 08:48 AM
RE: Odd Heater String 116X - by ipwizard - 04-20-2013, 10:04 AM
RE: Odd Heater String 116X - by 7estatdef - 04-20-2013, 08:22 PM
RE: Odd Heater String 116X - by Mondial - 04-20-2013, 10:09 PM
RE: Odd Heater String 116X - by 7estatdef - 04-21-2013, 02:01 PM
RE: Odd Heater String 116X - by 7estatdef - 04-22-2013, 05:24 PM
RE: Odd Heater String 116X - by Mondial - 04-22-2013, 06:37 PM
RE: Odd Heater String 116X - by 7estatdef - 04-22-2013, 09:12 PM
RE: Odd Heater String 116X - by Mondial - 04-22-2013, 10:23 PM
RE: Odd Heater String 116X - by chris25260880 - 04-23-2013, 11:23 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
