Who's in Michigan that would like a GE Colorama CHEAP?
Tell you what.. if someone will give this a good home, I'll PAY for it and you can just pick it up. I just don't want to see this go to being a bar or a digital entertainment center... not at that price.
There are currently 10555 online users. [Complete List]
» 3 Member(s) | 10552 Guest(s)
