Sterling Concertone Console
Nostalgia Air has schematics for 30 or so Sterling models, including one called "8 Tube Receiver." I only looked at a few and didn't find one that matched your tube set, but it might be there.
http://www.nostalgiaair.org/Resources/396/T0000396.htm
John Honeycutt
Sterling Concertone Console - by Jayce - 04-17-2013, 08:45 PM
RE: Sterling Concertone Console - by Arran - 04-17-2013, 09:27 PM
RE: Sterling Concertone Console - by Jayce - 04-17-2013, 09:45 PM
RE: Sterling Concertone Console - by BrendaAnnD - 04-17-2013, 10:07 PM
RE: Sterling Concertone Console - by Arran - 04-17-2013, 11:44 PM
RE: Sterling Concertone Console - by y2kbruce - 04-18-2013, 08:01 AM
RE: Sterling Concertone Console - by Jayce - 04-18-2013, 03:33 PM
RE: Sterling Concertone Console - by 7estatdef - 04-18-2013, 06:46 PM
RE: Sterling Concertone Console - by Jayce - 04-18-2013, 10:02 PM
RE: Sterling Concertone Console - by 7estatdef - 04-19-2013, 06:08 PM
RE: Sterling Concertone Console - by Raleigh - 04-23-2013, 04:01 PM
