40-120 Antenna Loop
Thanks Jim - that would be appreciated. It appears almost like another loose wound coil that is perpendicular to the one on the frame, but with some turns that are cut. What a mess...
40-120 Antenna Loop - by TonyJSenior - 12-11-2007, 10:45 PM
[No subject] - by Jim Dutridge - 12-12-2007, 07:08 AM
[No subject] - by TonyJSenior - 12-12-2007, 08:15 AM
[No subject] - by TonyJSenior - 12-12-2007, 10:33 PM
[No subject] - by Jim Dutridge - 12-13-2007, 03:58 PM
[No subject] - by TonyJSenior - 12-13-2007, 08:47 PM
[No subject] - by TonyJSenior - 12-14-2007, 11:07 AM
Philco 91 Tuning Condenser
There are currently 9855 online users. [Complete List]
» 1 Member(s) | 9854 Guest(s)
