Who's in Michigan that would like a GE Colorama CHEAP?
hey Micheal Dennis...this radio is just a little south of you! Actually, the set is in very southwest lower Michigan...closer to Indiana or Illinois folks. Take care all. Gary
There are currently 9981 online users. [Complete List]
» 3 Member(s) | 9978 Guest(s)
