Rookie Question
Hi Jake,
50T1482 is a good Philco model number.
Service information is covered in Sam's 128-11. Some libraries keep these.
Possibly the phono pickup is bad.
Also, with all vintage electronics, the electrolytic and paper capacitors should be changed before they fail and cause major damage.
Carl
Northern Panhandle, WV
Rookie Question - by Guest - 12-14-2007, 11:19 AM
[No subject] - by Carl Travis - 12-14-2007, 11:56 AM
[No subject] - by planigan - 12-17-2007, 02:32 AM
There are currently 8913 online users. [Complete List]
» 2 Member(s) | 8911 Guest(s)
