Weird sound when shutting of RCA 56X
Hey Morzh,
That did it. Just a little spray into the control and...no noise.
Eric
Eric
The Villages, FL
RE: Weird sound when shutting of RCA 56X - by Eric Adams - 04-26-2013, 01:00 PM
There are currently 9784 online users. [Complete List]
» 3 Member(s) | 9781 Guest(s)
