Just bought a Philco B-1756
Nice and neat!!! I seen that goo the seems to come out of the 1950's plastics A little bit of OMS or WD-40 seems to clean it off ok.
Just bought a Philco B-1756 - by FStephenMasek - 04-07-2008, 10:56 PM
RE: Just bought a Philco B-1756 - by 7estatdef - 04-26-2013, 09:34 PM
RE: Just bought a Philco B-1756 - by Ron Ramirez - 04-12-2014, 10:41 PM
RE: Just bought a Philco B-1756 - by Arran - 05-21-2014, 10:43 PM
[No subject] - by Doug Houston - 04-09-2008, 10:48 PM
[No subject] - by FStephenMasek - 05-27-2008, 01:37 AM
[No subject] - by Don Lind - 05-27-2008, 04:17 PM
Philco 91 Tuning Condenser
