Tom another model you see this on is the 46-1209 it was a 1946 model but Philco carried it over into mid-1947. For 1947 there was a model 47-1230 and they shared the same cabinet and phono, so much so that in some 1209 models you will find a brown wedge to hide the FM (1209 hand 3 locations on the band selector decal, 1230 had 4 locations on the band selector decal and on the brown wedged 1209's the positions did not alway line up per the switch setting.
38-12/39-12 - by zenith82 - 11-16-2005, 08:09 AM
[No subject] - by 49Stude63 - 11-16-2005, 01:53 PM
[No subject] - by Ron Ramirez - 11-21-2005, 10:50 AM
[No subject] - by Ron Ramirez - 11-22-2005, 12:23 PM
[No subject] - by zenith82 - 11-22-2005, 08:06 PM
[No subject] - by Ron Ramirez - 11-22-2005, 10:15 PM
[No subject] - by zenith82 - 11-22-2005, 11:56 PM
[No subject] - by Ron Ramirez - 11-23-2005, 12:02 AM
Eico 232 VTVM Schematic
There are currently 10368 online users. [Complete List]
» 1 Member(s) | 10367 Guest(s)
