philco 51 chaissis
need a picture of the 51 chassis , have a 551 clock that uses this both filter capacitors missing when i acquired it all tube and speaker were missing want to be sure as possible before powering up all wiring leading to filters is not there also have question s about choke on this model
philco 51 chaissis - by ckc - 12-17-2007, 11:06 AM
[No subject] - by Ron Ramirez - 12-19-2007, 11:14 AM
Philco 91 Tuning Condenser
There are currently 10510 online users. [Complete List]
» 2 Member(s) | 10508 Guest(s)
