Trouble IDing Philco Cap Can
Thanks to the both of you for your help. I believe I'll go with the 1ufd or 2ufd just because the size of the can dictates a larger size capacitor. A smaller capacitor would have been put into a mica block or just a mica cap itself installed.
Now I have to figure out what's going on with this "Micamold" cap that reads .006ufd but the parts list calls it out as a .06ufd. #42. It goes between the plate, pin 2 and whatever pin 5 is on the 79 output tube. Any ideas on what I should trust? The reading of the Micamold or the parts list? I've read that if you see a Micamold just throw it away.
[Image: http://speakeasyradios.com/yahoo_site_ad...15_std.jpg]
Pepperoni
"It's Nice To Be Nice To The Nice"
Major Frank Burns Mash 4077th
Trouble IDing Philco Cap Can - by Pepperoni - 04-27-2013, 12:50 PM
RE: Trouble IDing Philco Cap Can - by ipwizard - 04-27-2013, 01:50 PM
RE: Trouble IDing Philco Cap Can - by Pepperoni - 04-27-2013, 03:40 PM
RE: Trouble IDing Philco Cap Can - by ipwizard - 04-28-2013, 01:45 AM
RE: Trouble IDing Philco Cap Can - by Pepperoni - 04-28-2013, 11:41 AM
RE: Trouble IDing Philco Cap Can - by Mondial - 04-28-2013, 12:04 PM
RE: Trouble IDing Philco Cap Can - by Pepperoni - 04-28-2013, 03:08 PM
RE: Trouble IDing Philco Cap Can - by BrendaAnnD - 04-28-2013, 03:24 PM
RE: Trouble IDing Philco Cap Can - by Pepperoni - 04-28-2013, 04:48 PM
RE: Trouble IDing Philco Cap Can - by Mondial - 04-28-2013, 06:29 PM
RE: Trouble IDing Philco Cap Can - by Pepperoni - 04-28-2013, 08:49 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
