Trouble IDing Philco Cap Can
That cap is your parasitic oscillation supressor cap. Seeing as the tone control is also across the same points, a .06 seems quite high, and would affect the high end frequency response. My gut tells me that the .06 is a typo, but others here may be more familiar with the circuit.
Still in all, good idea to replace the Micamold, since it's just another paper cap in disguise.
Trouble IDing Philco Cap Can - by Pepperoni - 04-27-2013, 12:50 PM
RE: Trouble IDing Philco Cap Can - by ipwizard - 04-27-2013, 01:50 PM
RE: Trouble IDing Philco Cap Can - by Pepperoni - 04-27-2013, 03:40 PM
RE: Trouble IDing Philco Cap Can - by ipwizard - 04-28-2013, 01:45 AM
RE: Trouble IDing Philco Cap Can - by Pepperoni - 04-28-2013, 11:41 AM
RE: Trouble IDing Philco Cap Can - by Mondial - 04-28-2013, 12:04 PM
RE: Trouble IDing Philco Cap Can - by Pepperoni - 04-28-2013, 03:08 PM
RE: Trouble IDing Philco Cap Can - by BrendaAnnD - 04-28-2013, 03:24 PM
RE: Trouble IDing Philco Cap Can - by Pepperoni - 04-28-2013, 04:48 PM
RE: Trouble IDing Philco Cap Can - by Mondial - 04-28-2013, 06:29 PM
RE: Trouble IDing Philco Cap Can - by Pepperoni - 04-28-2013, 08:49 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
