1940 Coronado C800 console- COMPLETED!
You can also use the EQ feature on your i-pod to even further tailor the sound going into your radio. I've found that the Jazz or R&B setting works well for improving the sound thru my Philco 47-1230 chassis by improving the BASS and TREBLE response.
There are currently 5603 online users. [Complete List]
» 2 Member(s) | 5601 Guest(s)
