  • 1 Vote(s) - 2 Average
Phono speed selector knob won't turn shaft
It looks like you might be missing the spring steel insert which fits in the slots across the hole in the knob. This is a thin leaf spring which puts pressure on the flat of the shaft and prevents the knob from turning on the shaft.
It might have come loose when you removed the knob. If its lost, you probably can fabricate a workable replacement from thin sheet metal.
RE: Phono speed selector knob won't turn shaft - by Mondial - 04-28-2013, 07:00 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
