Need Antenna Transformer Coils for Broadcast and Police
"Hey, ma... a rodent ate my coils."
Looks like it may be just the primaries of the two coils that have been shredded. These are pretty easy to rewind, given a little care.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
