  • 1 Vote(s) - 2 Average
Phono speed selector knob won't turn shaft
I wondered if the shaft was split, or just missing the insert - and unfortunately, looks like you're both right. Crapola !! I'm gonna have to have new shaft made and then make some kind of metal insert to go on the new shaft - so it can lock into the knob. Thanks people, I appreciate the help.
Cheers,
Mike
RE: Phono speed selector knob won't turn shaft - by ODPILOT - 04-28-2013, 08:54 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
