  • 1 Vote(s) - 5 Average
Thoughts on a McMurdo Silver Masterpiece VI Speaker
#44
I recently purchased a Mcmurdo Masterpiece with the chassis and clifton cabinet but no speaker or power supply. After reading some of these postings I feel somewhat foolish because it is clear that the missing components will not be easily acquired. Is there any point in keeping the parts that I have. The chassis is complete and the cabinet is in good condition.
RE: Thoughts on a McMurdo Silver Masterpiece VI Speaker - by kirwin - 04-29-2013, 11:08 AM
Users browsing this thread: 14 Guest(s)
There are currently 10213 online users. [Complete List]
» 3 Member(s) | 10210 Guest(s)
