  • 1 Vote(s) - 5 Average
Thoughts on a McMurdo Silver Masterpiece VI Speaker
#46
Kirwin
Agree with Arran. If your set were mine, I wouldn't hesitate to build my own amp/power supply and, if nothing else, use modern speakers as I have done. The Clifton cabinet is, from what I have read, highly desirable so you have the main "eye candy" - the tuner and the cabinet. A new amp/power supply and modern speakers would not be seen unless you turned the cabinet around, removed the back cover and showed people what was inside.
RE: Thoughts on a McMurdo Silver Masterpiece VI Speaker - by Ron Ramirez - 05-01-2013, 05:32 AM
Users browsing this thread: 15 Guest(s)
There are currently 10166 online users. [Complete List]
» 2 Member(s) | 10164 Guest(s)
