Is this a asbestos chassis liner?
I certainly does look like asbestos. It was pretty common in the 30's and 40's to use asbestos fiber sheet under the chassis and in the cabinet near power tubes. I have a Philco 40-120 with the same type of asbestos in the wooden cabinet under the chassis. The earliest Zenith Transoceanics also had asbestos under the chassis.
If it were my radio, I would try not to disturb it to minimize getting any fibers airborne. When working around it, wear a respirator approved for asbestos and do it over a disposable surface. It is usually recommended to thoroughly wet down the asbestos with water so it will not become airborne when disturbed.
Is this a asbestos chassis liner? - by conroyp - 05-01-2013, 12:22 PM
RE: Is this a asbestos chassis liner? - by Mondial - 05-01-2013, 12:57 PM
RE: Is this a asbestos chassis liner? - by morzh - 05-01-2013, 08:04 PM
RE: Is this a asbestos chassis liner? - by Arran - 05-01-2013, 10:15 PM
RE: Is this a asbestos chassis liner? - by morzh - 05-01-2013, 10:45 PM
RE: Is this a asbestos chassis liner? - by morzh - 05-01-2013, 10:56 PM
RE: Is this a asbestos chassis liner? - by morzh - 05-07-2013, 11:03 AM
There are currently 7132 online users. [Complete List]
» 1 Member(s) | 7131 Guest(s)
