  • 1 Vote(s) - 5 Average
Thoughts on a McMurdo Silver Masterpiece VI Speaker
#48
I think there is a radio club in Toronto? Not sure about that. I would definitely look into that if I were you. Which Masterpiece do you have? I have MP V and MP VI schematics. It would not be too difficult to build a suitable amp/power supply. The power transformer would be the most expensive part.
RE: Thoughts on a McMurdo Silver Masterpiece VI Speaker - by Ron Ramirez - 05-01-2013, 09:11 PM
Users browsing this thread: 15 Guest(s)
There are currently 10353 online users. [Complete List]
» 3 Member(s) | 10350 Guest(s)
