  • 1 Vote(s) - 5 Average
Thoughts on a McMurdo Silver Masterpiece VI Speaker
#52
Ron, how would you identify a Masterpiece VI amp/supply? I have something that looks very similar to what you have in your cabinet.
RE: Thoughts on a McMurdo Silver Masterpiece VI Speaker - by Mondial - 05-01-2013, 10:29 PM
Users browsing this thread: 14 Guest(s)
There are currently 10226 online users. [Complete List]
» 3 Member(s) | 10223 Guest(s)
