49-905 Questions
Question #2 - On the back of my 49-905 the label that relates to the antenna lug is missing.  I found a picture on-line that is not really readable but seems to indicate that if you want to use an external antenna you remove the blue wire lug from the screw and do something.  IF you want to use an FM dipole antenna you....???  Does anyone have a 49-905 with this label and if so would you transcribe what the label says for me.  Thanks in advance!!
[Image: https://www.dropbox.com/s/u2we2q6oguq66u....jpg?raw=1]
49-905 Questions - by klondike98 - 04-30-2013, 09:24 PM
RE: 49-905 Questions - by morzh - 04-30-2013, 10:01 PM
RE: 49-905 Questions - by klondike98 - 04-30-2013, 11:47 PM
RE: 49-905 Questions - by morzh - 05-01-2013, 10:42 AM
RE: 49-905 Questions - by klondike98 - 05-01-2013, 12:54 PM
RE: 49-905 Questions - by klondike98 - 05-01-2013, 11:52 PM
RE: 49-905 Question #3 - by klondike98 - 09-09-2013, 06:42 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
