38-116 bezel restore + Cabinet pics added!
Thanks gang, the mask pieces were cut on a silhouette cameo electronic cutter of the wife's. Program what you want and it does a really excellent job of making very nice precision cuts on in this case some adhesive back paper stock.
Jerry
RE: 38-116 bezel restore - by 7estatdef - 04-27-2013, 07:12 AM
RE: 38-116 bezel restore - by TA Forbes - 05-01-2013, 10:06 PM
RE: 38-116 bezel restore - by jerryhawthorne - 05-02-2013, 12:09 AM
RE: 38-116 bezel restore - by Ron Ramirez - 05-02-2013, 07:29 AM
RE: 38-116 bezel restore - by jerryhawthorne - 05-02-2013, 02:55 PM
RE: 38-116 bezel restore - by Ron Ramirez - 05-02-2013, 03:43 PM
RE: 38-116 bezel restore - by jerryhawthorne - 05-02-2013, 04:49 PM
RE: 38-116 bezel restore - by Ron Ramirez - 05-02-2013, 08:14 PM
RE: 38-116 bezel restore - by jerryhawthorne - 05-02-2013, 08:47 PM
RE: 38-116 bezel restore - by jerryhawthorne - 05-05-2013, 05:35 PM
