Philco Model 131?
Well, at that price, I thought about picking it up...but I do not need it. Too bad you missed out. Honestly, though, I am surprised it lasted as long as it did before being snapped up.
Philco Model 131? - by Chris Drumma - 12-07-2007, 02:12 PM
[No subject] - by Chuck Schwark - 12-07-2007, 02:49 PM
[No subject] - by Chris Drumma - 12-07-2007, 03:07 PM
[No subject] - by Chuck Schwark - 12-07-2007, 04:30 PM
[No subject] - by Chris Drumma - 12-07-2007, 06:00 PM
[No subject] - by Chuck Schwark - 12-07-2007, 06:41 PM
[No subject] - by Chris Drumma - 12-11-2007, 09:14 AM
[No subject] - by Ron Ramirez - 12-19-2007, 10:57 AM
[No subject] - by Chris Drumma - 12-19-2007, 04:00 PM
[No subject] - by Ron Ramirez - 12-19-2007, 04:43 PM
[No subject] - by Chris Drumma - 12-19-2007, 06:33 PM
Philco 91 Tuning Condenser
There are currently 10193 online users. [Complete List]
» 2 Member(s) | 10191 Guest(s)
