48-1262 stumped
See if your rectifier tube is shorted or very leaky.
Shorts do not make capacitors blow.
Although it is always a good idea to check for them.
48-1262 stumped - by ke5yum - 05-02-2013, 08:40 AM
RE: 48-1262 stumped - by morzh - 05-02-2013, 10:28 AM
RE: 48-1262 stumped - by Steve Davis - 05-02-2013, 11:13 AM
RE: 48-1262 stumped - by morzh - 05-02-2013, 11:58 AM
RE: 48-1262 stumped - by ke5yum - 05-02-2013, 01:23 PM
RE: 48-1262 stumped - by morzh - 05-02-2013, 04:25 PM
RE: 48-1262 stumped - by Ron Ramirez - 05-02-2013, 07:57 PM
RE: 48-1262 stumped - by morzh - 05-02-2013, 08:27 PM
RE: 48-1262 stumped - by Ron Ramirez - 05-02-2013, 08:28 PM
RE: 48-1262 stumped - by morzh - 05-02-2013, 08:33 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
