38-116 bezel restore + Cabinet pics added!
All in the name of originality, Jerry.
Now, perhaps you could market those masks to other folks who are stuck with escutcheons that were polished to a bright brass and have lost all of their original patina along with the pattern. Seriously. It might be a nice little money-maker for you.
RE: 38-116 bezel restore - by 7estatdef - 04-27-2013, 07:12 AM
RE: 38-116 bezel restore - by TA Forbes - 05-01-2013, 10:06 PM
RE: 38-116 bezel restore - by jerryhawthorne - 05-02-2013, 12:09 AM
RE: 38-116 bezel restore - by Ron Ramirez - 05-02-2013, 07:29 AM
RE: 38-116 bezel restore - by jerryhawthorne - 05-02-2013, 02:55 PM
RE: 38-116 bezel restore - by Ron Ramirez - 05-02-2013, 03:43 PM
RE: 38-116 bezel restore - by jerryhawthorne - 05-02-2013, 04:49 PM
RE: 38-116 bezel restore - by Ron Ramirez - 05-02-2013, 08:14 PM
RE: 38-116 bezel restore - by jerryhawthorne - 05-02-2013, 08:47 PM
RE: 38-116 bezel restore - by jerryhawthorne - 05-05-2013, 05:35 PM
There are currently 10270 online users. [Complete List]
» 1 Member(s) | 10269 Guest(s)
