Philco 71b Filter Condenser Bank Question
Also am yet again puzzled, and still a novice at radio restoration and troubleshooting. I tested all the tubes, this model uses a 42 for audio output, the st type already in the chassis tested bad and quite weak. I only have several Globe type 42's in my stock. It tested good, and I will use it as a replacement for the initial power-up. I first put the set in series with a dim bulb tester just to see if the transformer has any shorts and it didn't as I expected. I did tune the dial to see if I would get anything but didn't, most likely because of the voltage limiter caused by the bulb. I then did a slow power-up with the power cord plugged into a variac. The end result was; all tubes had a glow, there was also a 60 cycle hum heard when I increased the volume pot, it went away when the volume was at zero.
The most concerning thing is that I did not get any other type of noise out the set for those 3 minutes. I am hoping that a full recap of the electrolytics and caps will fix the problem, this is my first encounter with no noise from the speaker on an initial power up.
I also noticed the mica trimmers that come off each section of the three gang available capacitor are still present, but the second one is chipped a bit and the third one is bent up on one side as in the picture. I know there could be quite a few factors contributing but, could this of caused the silence in the set?
RE: Philco 71b Filter Condenser Bank Question - by Philco281989 - 05-02-2013, 09:09 PM
Help on checking the coils - by Philco281989 - 05-03-2013, 07:04 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7089 online users. [Complete List]
» 1 Member(s) | 7088 Guest(s)
