66B Tombstone
Ah, a 60MB. Neat, I always felt that cabinet design was definitely European-influenced. You did very well on that, even if the cabinet does need major work. Someone recently sold just the chassis to a 60 for around $56 or so Icon_exclaim which I feel is WAY out of line for just a non-working 60 chassis. Somebody wanted that one pretty badly. But I digress...
Veneer was glued to the substrate; some trim pieces were nailed on with very small nails or glued on, depending on the radio.
Instructions for posting photos on the Phorum may be found here:
http://philcoradio.com/phorum/showthread.php?tid=29
http://philcoradio.com/phorum/showthread.php?tid=4371
66B Tombstone - by Chris Drumma - 12-19-2007, 04:08 PM
[No subject] - by Ron Ramirez - 12-19-2007, 04:58 PM
[No subject] - by Chris Drumma - 12-19-2007, 05:40 PM
[No subject] - by Ron Ramirez - 12-19-2007, 08:44 PM
[No subject] - by Chuck Schwark - 12-19-2007, 10:06 PM
Eico 232 VTVM Schematic
There are currently 9022 online users. [Complete List]
» 2 Member(s) | 9020 Guest(s)
