  • 1 Vote(s) - 5 Average
Potential fire from hot resistor?
Well, all depends on whether the heat has a way of escaping. You do realize that even a low temp heater if well insulated can deliver enough heat to ignite just about anything.
A good example is when old lampshades were covered with newspapers and would catch fire.
However 7W (and a 7W resistor will not be made to dissipate 7W; it is probably 3-4W) is not 40-70W of an incandescent lightbulb, and thisck wood is not thin paper, and the heat has some way of escaping as the radios were designed with this in mind (well, most of them, I guess).
Potential fire from hot resistor? - by ODPILOT - 05-02-2013, 09:20 PM
RE: Potential fire from hot resistor? - by morzh - 05-02-2013, 09:47 PM
RE: Potential fire from hot resistor? - by morzh - 05-02-2013, 11:38 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
