Philco 71b Filter Condenser Bank Question
Quote:I also looked on "Philco Repair Bench" and noticed that this part number is also listed, but states 2 under number of papers, does this mean there are two .5's or just one?
I checked that site too:
http://www.philcorepairbench.com/metalcap.htm
Have no idea what 2 papers means but I do know it is just one 0.5 uF capacitor for P/N 3583.
- Geoff
RE: Philco 71b Filter Condenser Bank Question - by Geoff - 05-03-2013, 12:52 AM
Help on checking the coils - by Philco281989 - 05-03-2013, 07:04 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7191 online users. [Complete List]
» 1 Member(s) | 7190 Guest(s)
