37-670 broken band switch lever
Here is a link to a tombstone version : http://www.antiqueradios.com/gallery/v/P...0.jpg.html
I'd have to believe that the knobs and lever is the same for both the tombstone and console versions. Often times a set of knobs pops up on eBay, or Ron has some resource links that may have them as well.
37-670 broken band switch lever - by Guest - 12-19-2007, 07:44 PM
[No subject] - by TonyJSenior - 12-19-2007, 09:01 PM
[No subject] - by Ron Ramirez - 12-19-2007, 09:12 PM
[No subject] - by Ron Ramirez - 12-26-2007, 08:59 PM
Philco 91 Tuning Condenser
There are currently 9206 online users. [Complete List]
» 1 Member(s) | 9205 Guest(s)
