  • 1 Vote(s) - 5 Average
71b, please help with checking coils
No I did not do any voltage checks, where would I start.
RE: 71b, please help with checking coils - by Philco281989 - 05-04-2013, 08:51 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7210 online users. [Complete List]
» 1 Member(s) | 7209 Guest(s)
