Is the Philco 39-25T model the same exact chassis as the 39-25XF console? Can I put a 39-25T chassis into a 39-25XF console cabinet?
Thanks
Chris
39-25 - by Chris Drumma - 12-20-2007, 11:38 AM
[No subject] - by Ron Ramirez - 12-20-2007, 12:58 PM
[No subject] - by Chris Drumma - 12-21-2007, 11:53 AM
[No subject] - by Ron Ramirez - 12-22-2007, 03:39 PM
[No subject] - by Chris Drumma - 12-23-2007, 08:18 AM
Eico 232 VTVM Schematic
There are currently 8798 online users. [Complete List]
» 2 Member(s) | 8796 Guest(s)
