Philco 38 – 5 disassembly challenges
Pull harder, just don't use a tool or pry bar. Some people have glued them on for one reason or another. That could be a problem.
The rubber under the tuning cap needs to be replaced, and, if it has one, the rubber bushing at the back end of the cap also.
248
RE: Philco 38 – 5 disassembly challenges - by Phlogiston - 05-05-2013, 03:23 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
