AVC Live for Zenith T/O B600 ???
I know I keep telling this to everyone and by now have become redundant, but: Geoff, do check your isolation xfmer isolation, do not trust labels. Mainly, take the meter and check the continuity between both output wires and the Earth GND. Should not be any.
AVC Live for Zenith T/O B600 ??? - by Geoff - 05-05-2013, 01:16 AM
RE: AVC Live for Zenith T/O B600 ??? - by Mondial - 05-05-2013, 11:50 AM
RE: AVC Live for Zenith T/O B600 ??? - by Geoff - 05-05-2013, 12:35 PM
RE: AVC Live for Zenith T/O B600 ??? - by morzh - 05-05-2013, 03:35 PM
