Who can restore my 37-630?
Does anyone around Toledo Ohio or southern Michigan restores these old radios?
Who can restore my 37-630? - by marilynmonroe - 05-05-2013, 04:29 PM
RE: Who can restore my 37-630? - by Phlogiston - 05-05-2013, 07:10 PM
RE: Who can restore my 37-630? - by marilynmonroe - 05-05-2013, 10:02 PM
RE: Who can restore my 37-630? - by thirtiesradio - 05-05-2013, 10:36 PM
RE: Who can restore my 37-630? - by morzh - 05-06-2013, 08:37 PM
RE: Who can restore my 37-630? - by marilynmonroe - 05-06-2013, 09:15 PM
RE: Who can restore my 37-630? - by dixierat - 05-06-2013, 10:31 PM
RE: Who can restore my 37-630? - by Jim Dutridge - 05-07-2013, 08:28 AM
Who can restore my 37-630? - by marilynmonroe - 05-05-2013, 04:40 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
