About 2' deep, over 3' wide, and over 4' tall.
38-116 - by vinzer - 05-06-2013, 08:56 PM
RE: 38-116 - by Phlogiston - 05-06-2013, 10:15 PM
RE: 38-116 - by Arran - 05-06-2013, 11:58 PM
RE: 38-116 - by dixierat - 05-07-2013, 10:27 AM
RE: 38-116 - by vinzer - 05-07-2013, 11:28 AM
RE: 38-116 - by Ron Ramirez - 05-07-2013, 02:17 PM
RE: 38-116 - by vinzer - 05-07-2013, 05:33 PM
RE: 38-116 - by Phlogiston - 05-07-2013, 05:42 PM
RE: 38-116 - by vinzer - 05-07-2013, 05:58 PM
RE: 38-116 - by Ron Ramirez - 05-07-2013, 07:43 PM
RE: 38-116 - by Ron Ramirez - 05-07-2013, 07:50 PM
RE: 38-116 - by vinzer - 05-07-2013, 08:48 PM
RE: 38-116 - by vinzer - 05-07-2013, 08:59 PM
RE: 38-116 - by Mondial - 05-07-2013, 09:02 PM
RE: 38-116 - by vinzer - 05-07-2013, 09:07 PM
RE: 38-116 - by Mondial - 05-07-2013, 09:17 PM
RE: 38-116 - by Ron Ramirez - 05-07-2013, 09:55 PM
RE: 38-116 - by Mondial - 05-07-2013, 10:14 PM
RE: 38-116 - by Ron Ramirez - 05-07-2013, 10:18 PM
RE: 38-116 - by PhilcoJohn - 05-08-2013, 07:38 AM
RE: 38-116 - by PhilcoJohn - 05-08-2013, 07:40 AM
RE: 38-116 - by Jayce - 05-08-2013, 12:17 PM
RE: 38-116 - by PhilcoJohn - 05-08-2013, 03:15 PM
RE: 38-116 - by palegreenthumb - 05-10-2013, 10:19 AM
RE: 38-116 - by vinzer - 05-10-2013, 11:46 AM
RE: 38-116 - by vinzer - 05-11-2013, 10:07 PM
RE: 38-116 - by Tim Tress - 06-18-2013, 11:00 PM
RE: 38-116 - by vinzer - 06-19-2013, 05:16 PM
RE: 38-116 - by PhilcoJohn - 06-20-2013, 08:19 PM
RE: 38-116 - by vinzer - 06-20-2013, 09:56 PM
RE: 38-116 - by PhilcoJohn - 06-21-2013, 09:03 PM
RE: 38-116 - by vinzer - 06-22-2013, 11:59 AM
RE: 38-116 - by SteveJB - 06-22-2013, 04:19 PM
RE: 38-116 - by vinzer - 06-22-2013, 06:25 PM
RE: 38-116 - by PhilcoJohn - 06-23-2013, 07:04 AM
RE: 38-116 - by morzh - 06-23-2013, 12:24 PM
RE: 38-116 - by vinzer - 06-23-2013, 05:54 PM
RE: 38-116 - by vinzer - 11-27-2013, 01:03 PM
RE: 38-116 - by PhilcoJohn - 11-27-2013, 07:46 PM
RE: 38-116 - by vinzer - 11-27-2013, 08:04 PM
RE: 38-116 - by PhilcoJohn - 12-06-2013, 08:16 PM
RE: 38-116 - by vinzer - 12-06-2013, 11:24 PM
RE: 38-116 - by PhilcoJohn - 12-07-2013, 07:45 PM
RE: 38-116 - by vinzer - 12-07-2013, 09:45 PM
Philco 91 Tuning Condenser
