Is this a asbestos chassis liner?
That's one of the thickest "A" pads I have seen.
I it were mine, I'd apply a paint/clear lacquer with a brush. and leave it in place.
Is this a asbestos chassis liner? - by conroyp - 05-01-2013, 12:22 PM
RE: Is this a asbestos chassis liner? - by morzh - 05-01-2013, 08:04 PM
RE: Is this a asbestos chassis liner? - by Arran - 05-01-2013, 10:15 PM
RE: Is this a asbestos chassis liner? - by morzh - 05-01-2013, 10:45 PM
RE: Is this a asbestos chassis liner? - by morzh - 05-01-2013, 10:56 PM
RE: Is this a asbestos chassis liner? - by gary rabbitt - 05-07-2013, 02:33 AM
RE: Is this a asbestos chassis liner? - by morzh - 05-07-2013, 11:03 AM
There are currently 11264 online users. [Complete List]
» 2 Member(s) | 11262 Guest(s)
