Is this a asbestos chassis liner?
Go to the auto parts store and by a can of high-temp ceramic exhaust header paint and encapsulate it.
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
Is this a asbestos chassis liner? - by conroyp - 05-01-2013, 12:22 PM
RE: Is this a asbestos chassis liner? - by morzh - 05-01-2013, 08:04 PM
RE: Is this a asbestos chassis liner? - by Arran - 05-01-2013, 10:15 PM
RE: Is this a asbestos chassis liner? - by morzh - 05-01-2013, 10:45 PM
RE: Is this a asbestos chassis liner? - by morzh - 05-01-2013, 10:56 PM
RE: Is this a asbestos chassis liner? - by morzh - 05-07-2013, 11:03 AM
RE: Is this a asbestos chassis liner? - by PhilcoMike - 05-07-2013, 12:14 PM
There are currently 7207 online users. [Complete List]
» 1 Member(s) | 7206 Guest(s)
