Just Picked Up 38-116 -Questions
Nice find and all the tube shields to boot! Could that strange one on the RF deck be the aluminium you were referring to on another post Ron? Only worked on one of these and it didn't have that type of shield. Perhaps now I have seen one? And yes, as Ron said, to access the replacement of the station markers you need to remove the two knobs and then the 3 or is it 4 screws holding that round plate. Then you will be able to slip new station markers into place.
Jerry
Just Picked Up 38-116 -Questions - by RoyG - 05-07-2013, 03:11 PM
RE: Just Picked Up 38-116 -Questions - by RoyG - 05-07-2013, 08:15 PM
RE: Just Picked Up 38-116 -Questions - by RoyG - 05-07-2013, 08:18 PM
RE: Just Picked Up 38-116 -Questions - by jerryhawthorne - 05-07-2013, 10:04 PM
RE: Just Picked Up 38-116 -Questions - by RoyG - 05-07-2013, 10:13 PM
Philco 91 Tuning Condenser
There are currently 5740 online users. [Complete List]
» 1 Member(s) | 5739 Guest(s)
