5Y3 question
Your fan is likely not needed. These radios are designed to work with everything the way it was.
As far as a SS replacement 5Y3, it would run cooler, but it would also raise the odds of shorting out the input filter because of the instantaneous, unloaded B+ voltage. Ideally, the original tube allows all the other tubes to warm up so that most or all of the load is present by the time full B+ is available.
5Y3 question - by shaler78 - 05-07-2013, 10:35 PM
RE: 5Y3 question - by BrendaAnnD - 05-07-2013, 10:52 PM
RE: 5Y3 question - by morzh - 05-07-2013, 10:52 PM
RE: 5Y3 question - by Mondial - 05-07-2013, 10:57 PM
RE: 5Y3 question - by shaler78 - 05-07-2013, 11:33 PM
RE: 5Y3 question - by gary rabbitt - 05-14-2013, 08:30 PM
RE: 5Y3 question - by codefox1 - 05-16-2013, 01:31 PM
RE: 5Y3 question - by morzh - 05-16-2013, 02:09 PM
RE: 5Y3 question - by shaler78 - 05-16-2013, 07:40 PM
RE: 5Y3 question - by gary rabbitt - 05-17-2013, 12:00 AM
RE: 5Y3 question - by shaler78 - 05-17-2013, 12:14 AM
RE: 5Y3 question - by BrendaAnnD - 05-17-2013, 12:29 AM
RE: 5Y3 question - by Arran - 05-17-2013, 01:11 AM
RE: 5Y3 question - by BrendaAnnD - 05-17-2013, 02:25 AM
RE: 5Y3 question - by Marsupial - 05-17-2013, 10:13 AM
RE: 5Y3 question - by codefox1 - 05-17-2013, 01:15 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
