When did the terminology change from condenser to capacitor
Cycles were replaced with Hertz sometime in the 60's. Personally, I still like to call them cycles, a much better descriptive term.
RE: When did the terminology change from condenser to capacitor - by BrendaAnnD - 05-08-2013, 03:54 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7100 online users. [Complete List]
» 1 Member(s) | 7099 Guest(s)
