When did the terminology change from condenser to capacitor
Agreed KHC and MHZ are correct, and I am now an old timer.
RE: When did the terminology change from condenser to capacitor - by codefox1 - 05-08-2013, 08:57 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
