Dead Tube Tester
I am wondering if it can be repaired. Oddly, the radio guys I know around here will not even try to repair a tester when something goes wrong with it, so thought once one was dead that was it. Of course of the transformer in mine died...
Dead Tube Tester - by Jayce - 05-08-2013, 12:21 PM
RE: Dead Tube Tester - by Chuck Schwark - 05-08-2013, 12:27 PM
RE: Dead Tube Tester - by morzh - 05-08-2013, 02:58 PM
RE: Dead Tube Tester - by codefox1 - 05-08-2013, 03:43 PM
RE: Dead Tube Tester - by morzh - 05-08-2013, 04:28 PM
RE: Dead Tube Tester - by Jayce - 05-08-2013, 10:37 PM
RE: Dead Tube Tester - by morzh - 05-08-2013, 11:08 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
