When did the terminology change from condenser to capacitor
International System of Units aka SI.
The seven SI base units : kelvin (temperature), second (time), metre (length), kilogram (mass), candela (luminous intensity), mole (amount of substance) and ampere (electric current). Tons of (useful?) info on the net.
(I didn't know what it meant either@)
RE: When did the terminology change from condenser to capacitor - by codefox1 - 05-09-2013, 12:27 AM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
