Another Silvertone!
It's actually a mid range model, it looks like it has about 8 tubes including the magic eye, but one of which is probably an extra RF amp since it has a three gang tuning condenser. It is probably a good performer, most sets with a tuned RF amplifier stage are.
Another Silvertone! - by 37silverstreak - 05-07-2013, 08:36 PM
RE: Another Silvertone! - by NostalgiaRadioTime - 05-07-2013, 10:57 PM
RE: Another Silvertone! - by Paul Philco322 - 05-08-2013, 07:50 AM
RE: Another Silvertone! - by chris25260880 - 05-08-2013, 11:40 PM
RE: Another Silvertone! - by Arran - 05-09-2013, 01:37 AM
