more 41-250 questions
I have used the thin veneer on several radio cabinets and had good results. It may have been dumb luck. Icon_smile Where I needed thicker veneer to match existing veneer I just glued on extra layers.
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
more 41-250 questions - by electroubleshooter - 12-22-2007, 01:32 PM
[No subject] - by Ron Ramirez - 12-22-2007, 03:25 PM
[No subject] - by electroubleshooter - 12-22-2007, 05:50 PM
[No subject] - by Ron Ramirez - 12-22-2007, 06:49 PM
[No subject] - by Terry Judkins - 12-22-2007, 10:53 PM
[No subject] - by TonyJSenior - 12-23-2007, 12:17 AM
[No subject] - by Terry Judkins - 12-23-2007, 12:34 AM
[No subject] - by Ron Ramirez - 12-23-2007, 12:53 AM
[No subject] - by bill T - 12-23-2007, 09:59 AM
[No subject] - by FStephenMasek - 05-09-2008, 07:55 PM
There are currently 5427 online users. [Complete List]
» 2 Member(s) | 5425 Guest(s)
