old trick that works like new
I started working on a 38-10 that was incredibly grimy. Almost like it was in a kitchen and picked up years of cooking grease in the air. Or perhaps it was soot from a woodstove. Whatever it was, the top of the cabinet was black. It looked like someone spray painted it with flat black primer.
So, I tried an old trick I heard about years ago. I took a wooden scrub brush with short stiff bristles, and a container of goop (or gojo) hand cleaner. Coating the brush with the hand cleaner, I began to scrub the top of the cabinet and was amazed at how the grime just melted away, revealing a still decent finish. I found it worked best going against the grain or even in a circular motion. You don't have to worry about scratching the finish, a lot of pressure isn't neccessary. Just let the hand cleaner work its way in and it will loosen the grit and grime nicely.
Try it sometime before you decide to strip and refinish a dull looking cabinet. You just might be surprised how much you can salvage.
old trick that works like new - by NostalgiaRadioTime - 05-09-2013, 10:29 PM
RE: old trick that works like new - by Arran - 05-10-2013, 02:04 AM
RE: old trick that works like new - by FXpert - 05-10-2013, 06:39 AM
Philco 91 Restore Code ??
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
There are currently 2356 online users. [Complete List]
» 3 Member(s) | 2353 Guest(s)
