37-670 broken band switch lever
Kit
If you still need a photo of the band switch lever, I can take one of a 37-630 for you. While this model is smaller than the 37-670, the two should be similar enough to give you an idea of how it should look...
37-670 broken band switch lever - by Guest - 12-19-2007, 07:44 PM
[No subject] - by TonyJSenior - 12-19-2007, 09:01 PM
[No subject] - by Ron Ramirez - 12-19-2007, 09:12 PM
[No subject] - by Ron Ramirez - 12-26-2007, 08:59 PM
Philco 91 Tuning Condenser
There are currently 8721 online users. [Complete List]
» 1 Member(s) | 8720 Guest(s)
